BobR
- Aug 6, 2007
- Reaction score
- 0
- Location
- okanogan
- Make / Model
- ferd
- Manual
couldn't the clearance/function issues be overcome by using the t-case shifter and linkages (including the are from the tcase) that came with the tranny being installed. and perhaps opening up the hole in the floor.Hmm, that makes a bit of a difference.... an FM145 is two inches too short and you're going to be doing quite a lot of work to cram that in there.
The transfer case should work fine. But the shift lever won't. It was meant for a case mounted two inches further forward, so it's going to hit your dashboard.
Bob
