- Aug 23, 2015
- Reaction score
- 87
- Location
- Virginia
- Make / Model
- Ford
- Engine Type
- 2.9 V6
- Engine Size
- 2.9
- Automatic
- 2WD / 4WD
- 4WD
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 235/75/15
My 88 Bronco keeps dying even after charging the battery. I’ve tried 3 different batteries. The last one was recently tested good. When charging the battery the alternator is warm to the touch. Truck will start after a good charge. Once the truck is shut off, it will not start back up shortly afterwards after sitting.
My question is, if the alternator tests bad is a 65a sufficient. There are way more 80+ amp options for some reason. Truck does have factor A/C. Thanks!
