2.8 bogs and won't go over 58 MPH
rusty ol ranger
2.9 Mafia-Don
7,628
Michigan
177 CID
Does the 2.8 use fiber timing gears like the later 300's? Its rare but i have heard of them slipping (on 300's)
The low compression readings on all 6 that seemed to happen quickly kinda screams valve timing....atleast to me.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
yes. valve events are next.
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,803
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Jim Oaks
Administrator
Supporting Vendor
8,803
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
I swapped out the fuel pump, cap, rotor, and plugs. No change.
I guess I'll try to adjust the timing once I figure out how to get to the distributor bolt.
I'm getting beyond frustrated with this thing. I just want to get it running good again so I can get it out of my life.
17,953
SW Iowa
The last time I heard a guy say that he V8 swapped it and put the 2.8 where it belongs in the back of his corn crib...
FWIW it had enough blow by it would push the dipstick out and spray the exhaust manifold with oil. Stank to high heaven. Still started and drove fine.
Agree with checking the timing. Check for vacuum leaks too.
Jim Oaks
Administrator
Supporting Vendor
8,803
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
I've wondered if the valves aren't closing all the way resulting in the low compression and the engine running bad.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
AndyB.
142
Cincinnati, OH
If there was only a way you could test for valves not closing all the way. Maybe like someone suggested after the low compression, a leak down test?
How did it run before you rebuilt the carburetor?
Jim Oaks
Administrator
Supporting Vendor
8,803
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Ran like crap. Accelerator pump leaked. Ran great for about 3-months after I rebuilt it.
rusty ol ranger
2.9 Mafia-Don
7,628
Michigan
177 CID
I still think a timing gear slipped
17,953
SW Iowa
Valves are adjustable too. If one is way loose it would not be closing but then you would have no compression rather than low compression.
Uncle Gump
Token Old Guy
13,541
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
If it was loose... it wouldn't be opening all the way.
If the valves aren't closing all the way... zero compression
17,953
SW Iowa
If the valves aren't closing all the... zero compression
My angle was if a valve wasn't closing when you went to adjust it the setting would be loose. Like probably way loose.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
so the distribultor gear is perfect? they like to eat those.
if so..
yeah....valve events.
pull the covers and plugs...and basically degree it in. make damn sure that tdc is tdc and the valve events are on.
from there assuming you have a mag base or fixture....can just use bracket bar or whatever....valve events.
