frozenrabbit
- Jul 5, 2022
- 1
- ohio
- Ranger
94 ranger 2.3l, unknown actual miles.
has been using oil, only has visible smoke some days, if parked overnight on an angle. Just replaced all valve stem seals last week.
Was thinking rings. Ran a compression test, dry numbers were 155, 160, 165, 170. Fresh head earlier this year with proper lapped valves. Pressurized cylinders to replace valve seals, no excessive air leak down.
Isn't the compression numbers in a range for not being worn rings?
No leaks anywhere, block, pan, and below rear main are all clean.
I did have some oil behind the throttle body when changing valve seals, what would cause that?
