2.3L ('02-'11) 2.3 L I4 and camper top
maasiano
Firefighter
California
Hello,
I have a 2003 Ford Ranger, with a 2.3 L cyl. I was wondering if a camper shell would be too heavy for these trucks? I know they are super underpowered and I was wondering what other people have done or think. Going uphill on the freeway I am sometimes only able to push 50-55 mph, but I feel like that's pretty standard for these trucks. Are there possible upgrades?
Hope to hear from you all.
Marco
Uncle Gump
Token Old Guy
13,489
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Look at what gear ratio you have vs. tire size.
Sometimes a taller tire will kill the power.
maasiano
Firefighter
California
I have a completely stock truck rims are the 15in alloy.
Uncle Gump
Token Old Guy
13,489
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
it's not the wheel size... it's the tire size.
Check the door sticker to see what gear ratio you have. Take that info to the Tech Library... it will tell you what it has ( if it wasn't changed). You can also get factory tire size from the same sticker... compare that to what's on the truck.
maasiano
Firefighter
California
Thank you so much, i'll get back to you to you soon.
Jazzer
457
Indianapolis
Could you describe what type of ‘camper shell’ you’re thinking of?
I bought a ‘97 2.3 longbed with a fiberglass topper and it was a dog, not so much lacking power, but I knew I’d have to put stronger leaf springs in to handle the extra weight in the rear. I had a different ‘97 with an aluminum top and it was fine, powerwise and weightwise.
-Jazzer
Jim bow
Law Enforcement
B809207ang
The typical fiberglass canopy weighs less than 100 lbs.
maasiano
Firefighter
California
-Jazzer
I am planning on getting a fiberglass camper shell something like this.
Note: Mine isn't an extended cab, and I have the alloy 15in rims.
maasiano
Firefighter
California
I have the p225/70r15 100t toyo extensa a/s ww tires, I think the gear ratio is 3.73.
Plum Ranger XLT
29
Lawrenceburg, IN
I once had a 1984 Ranger that was a 2.0L 4 cylinder 4 speed short bed that I bought a used cap for the bed and I noticed there wasn't much a difference in power if at all since it was already underpowered to begin with.
scotts90ranger
4,389
Dayton Oregon
2.3 Turbo
With that size tire and 3.73 gears I would expect to be downshifting on inclines at highway speeds. The duratec has more power than the Lima but at higher rpm... That's the size tire I run on my Lima with 4.10 gears and it does fine but I have to downshift to 4th up some hills... RPM is your friend...
That said, the canopy will be fine...
