I think you have it backwards, your '85 should have the TK5, the '89 2.9L most likely is a M5OD-R1 (assuming 2WD).
However, the bellhousings between a 2.3 and 2.9 are not the same, so that pretty much makes whether the input shaft itself is the same or not a moot point.
it did have a tk5 in it but that blew i did a swap from a scrap yard but the m5r1 that they gave me makes some noise in 5th gear and they only have yard credit problem is they only have 2.9s the one i looked under had the tk5 in it it had the ribbed cover on the bottom but thanks for the reply
the bell housing from your old 4 cyl tk5, if you still have it, should swap onto the 6 cyl tk5 or get a v6 mazda trans and use the guts to fix yours, one from a 2.9 would be best as the gear ratios are the same
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
