1st gen TDI ranger, prerunner style build.
powerstrokekid
111
New London, Ohio
Solid Axle Swap 4x4
These wheels were off the bronco 2 I grew up in. They were sitting in the weeds at my grandparents. I cleaned them up and put new tires on. Total cost on the truck right now is about $550 including tires!
powerstrokekid
111
New London, Ohio
Solid Axle Swap 4x4
After about 15 miles of test drive and the only mechanical work being carburetor adjustment (besides fluid changes) I drove it to work (120 mile round trip) it did fine except for not having the power to use 5th gear. Not bad for sitting 15+ years
powerstrokekid
111
New London, Ohio
Solid Axle Swap 4x4
I’m still not sure if this is the ranger I will use for the tdi swap, but I’m giving it the winter to think about it. I plan to drive this through the winter and decide if a single cab is going to be enough room. Right now it it’s not, but I’m going to try thinner seats.
dvdswan
2,909
Seattle, WA
Ranger XLT 2WD
Free stuff is good, as long as it is something you can use.
chickenman
34
Kentucky
Epic im starting my own tdi swap journey 94 supercab 4x4 5 speed. 2004 TDI.
powerstrokekid
111
New London, Ohio
Solid Axle Swap 4x4
I replaced the dry rotten brake hoses and did front brakes. my buddy helped me with the rear, I’m not good with drum brakes. It stops so good now!
I straightened out the frame rail, it was tweaked a little from a bent stock bumper.
started making a bumper with scrap metal I have.
Blmpkn
Toilet enthusiast
6,422
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
powerstrokekid
111
New London, Ohio
Solid Axle Swap 4x4
I got thinner seats from my buddy and what a difference! There’s so much more room. I’m comfortable. So on that note, I will likely keep this truck and tdi swap it in the spring. I will drive this truck through the winter, fix little things with it and save up for the final swap parts.
powerstrokekid
111
New London, Ohio
Solid Axle Swap 4x4
Painted the bumper and then put silicone In between the stitch welds to prevent rust stains from seeping out hopefully.
:headbang:
ericbphoto
Overlander in development
TRS 25th Anniversary
16,761
Wellford, SC
6"
That looks real good. I like it.
Blmpkn
Toilet enthusiast
6,422
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Hell yeah, looks good.. nice work.
powerstrokekid
111
New London, Ohio
Solid Axle Swap 4x4
Well my buddys ranger that I was gonna use, he’s gonna do a 5.0 swap. We took the v tread off and put on some old school looking super swampers on! Looks sweet just figured I’d share.
