2.3L ('83-'97) 1994 2.3l Ranger Splash HELP WITH CODES PLEASE
davidmichaeldore
9
Port Neches, TX
Ford ranger
typically the difference between an $8 and a $20 haircut is way more than $12
CRANK/ NO START.
the truck lost power in the middle of the day then got it running that night, Next day same thing. next day stalled and hasn't started again in two weeks. fuel pump isn't even priming and getting codes
335
519
536
542
frozenrabbit
ohio
If you have a tach, when cranking it will register RPM, if the tach doesn't move, it's a bad crank sensor. I chased my for months thinking it was the hack repaired fuel pump wiring.
Crank sensor had a hair line crack, would run fine for days, then no start, random die and start back up after a few minutes, all random. No issues since replacement.
542 is a Fuel pump code. Could be the relay, swap around your relays to test.
Others are ERG circuit, Power steering pressure, and Brake circuit. None of those would cause no start.
Error codes:
