1994 2.3 liter no spark at one coil tower misfire
larry123
1994 ranger 2.3 liter
was mising on number three cylinder
new coil, new icm,
found a bad plug wire. now truck runs fairly well but now #3 cylinder is firing on the exhaust side but not on intake side.
one coil is not producing spark on the #3 tower but is on the #2 tower.
it has a new coil and have swapped coils. but #3 still does not fire at the coil
what could be the problem. the signal wire flashes like it is supposed to for #2#3 side and it flashes for the #1 #4 side. so what gives. can anyone help me
falcon61
Not sure, I,m similar..my keyed ignition coilpack base has melted the16ga. Jacket at the triplug.
Sent from my RCT6773W22 using Tapatalk
8,372
Couple of things:
When starting the 2.3l/2.5l engines only the exhaust side coil works, intake side coil won't start until RPMs are above 400-500
And how are you checking for spark?
Timing light connected to #3 wire with engine running is about the only way.
Because of the Waste Spark system used by Ford the 2 spark plugs on the 1 coil are wired in series, so if you pull off a plug wire to test for spark it may not spark because you have broken the series connection.
