1993 ford ranger wont start
awsskater4life76
garden city, MI
2.3l 4 cylinder
i have a 1993 ford ranger and last week i was on my home from work and in the middle of traffic it just turned off so i pushed it off the road went and put 5 gallons of gas when fueling i noticed gas poruing out of the filler hose it had a crack in it so pushed it home droped the tank when i was pulling the lines off i broke off the fuel sending unit line going into the gas lines. so now i replaced the filler neck and sending unit and now i hear the fuel pump working and it cranks over but doesnt start any ideas anyone?
awsskater4life76
garden city, MI
2.3l 4 cylinder
engine specs
2.3l 4 cylinder 5 speed 150000 miles tryed starting the battery, oil, abs, seatbelt, engine, light was on now just the oil, abs, seatbelt light just come on
DarkMax
Cocoa, FL
2.3L
Theres an emergency fuel shutoff in the 93 ranger, you can see the sticker when you lift the hood. Try and go though the process of resetting it and see if it helps. Also, with the key on, check the schrader valve to make sure you have adequate fuel pressure coming through the fuel lines. Next id check spark and then compression, if all of these are fine then the truck should start right up.
awsskater4life76
garden city, MI
2.3l 4 cylinder
where is the schrader valve at and to check it does fuel come out when started or do i need a pressure gauge?
lil_Blue_Ford
6,137
Butler, PA, USSA
4.9L
The emergency fuel shut off is electrical. If the pump is kicking on, then the shut off isn't tripped.
If there is pressure at the rail, fuel will spray everywhere when you press the schrader valve. I usually get a small screwdriver or something positioned and wrap a rag around and just hit it real quick. If the rag soaks fast, then there's pressure. If pretty much nothing happens, there is no pressure.
awsskater4life76
garden city, MI
2.3l 4 cylinder
i replaced the filler neck, sending unit, fuel filter and it still didnt turn over so i checked the shrader valve still has pressure and i can hear the pump kick on the emergency shut off is not triggered and the tank reads half full and the batterys good any ideas guys?
modelageek
14
Boston, MA
You said " it still didnt turn over" Did you mean it still will not start?
awsskater4life76
garden city, MI
2.3l 4 cylinder
the starter cranks but it still wont start
modelageek
14
Boston, MA
I bet your timing belt broke
awsskater4life76
garden city, MI
2.3l 4 cylinder
i checked the fuses and the coil pack and sparg plugs all good. the spark plug smelt like gas. it didnt fire up with starter fluid. and it has a vacuum. maybe the injectors?
modelageek
14
Boston, MA
You know the timing belt is different then the drive pulley belts(serpentine bely)the timing belt is behind a cover near the waterpump. I wonder if the belt skipped a tooth. If the timing is correct and you had a spark. Starter fluid should have done something
koda6966
61
The green part of NY.
2.9
Wait, you said the oil lights on? Check your oil level, it wouldn't keep you from starting but it would severely mess up your engine if you did.
IIRC the oil light comes on when your about two quarts low. Trust me, I know.
And have you done anything to the spark plug wires, distributor cap, or the little rotary thing lately? If you have you might have messed up your timing. You HAVE to start the timing with the first wire in the location of where the little rotating thing under the cap is. I'd tell you what the timing is supposed to be but my Rangers a V6, and I don't know the 4 cylinders that well.
modelageek
14
Boston, MA
the little rotating thing under the cap is called a rotor but he should not have one on his 93. he should have electronic distruberless ignition. I think he has a timing issue. imho, if not the belt can the crankshaft position sensor get so damaged to screw up the timing.
Have your tried to pull any codes?
