- Apr 25, 2022
- 8
- 29365
- Ford Ranger
I recently put a new long block in my 1993 Ford Ranger XLT 2wd 4.0 l V6. when I first put it all together and tried to start it for the first time it fired right up, no hesitation or anything. Still today is starts right up but runs like you got 3 spark plug wires off. It jerks, it has no power, I might go 100 miles on a half of a tank or gas. I have replaced everything, plugs, wires, core, MAP sensor and so on, if you have a question on something just ask, I can recall all of them. New fuel injectors also. No smoke coming from tail pipe. I bought a OBD1 checker, and I am getting codes 172 and that seems to mean it is running lean, and code 177 which is running rich. I am at a loss to what to do to it, I have checked for vacuum leaks by pulling the hoses and checking for any holes, tears, or brittle hoses, and then I took Carb cleaner while it was running and sprayed it in every nook and cranny I could find, all the hose ends, the length of the hose and around every gasket I could find and reach, and nothing. I can usually find the problem on stuff, but this thing is whooping my behind, nothing I do makes it worse or better. I am just ready to get it running correctly. Please any advice ideas, you know exactly what my problem is just any help will be greatly apricated. I just want to thank everyone who takes the time to read this. Please help
