Captaingreatvalue
- Oct 3, 2023
- Reaction score
- 1
- Location
- United States
- Make / Model
- Ford Ranger
- Manual
Hello everyone so I appreciate any advice yall can give just wanted to let yall know some info I have a 1992 ford ranger that has a 4 cyl 2.3l manual trans and since i acquired it in 2020 the speedometer has never worked accurately i recently replaced the vss as alot of youtubers and forums say that is a common issue i can tell you the gear was black and the speedo cable was replaced by the previous owner i saw it looked new after changing the vss the issue still remains and after thinking it was the speedometer it self that was bad i took it on test drive to watch the speedometer spin and i saw the cable was not spinning fast enough plus i took a drill and tested the speedometer and it worked like it should i purchased on evil bay the speedo gear with the most teeth which is 23 seeing the black one was a 20 hoping that is the fix or at least close enough but i have a feeling its the drive gear inside the transmission let me know what yall think
