1991 Ranger 2.9 to 93 explorer 4.0 swap.
hellgoat71
North Carolina
I recently just swapped out my 2.9 from my 91 Ranger and put in a 4.0 that came from a 93 Explorer I did get the engine wiring harness and ECU and headlight harness and all other electrical except for the dash harness so I'm having trouble combining the two if that makes any sense if anybody could please help me I think my problem would be on the driver side firewall under the hood
SenorNoob
579
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I thought combination was supposed to be plug and play? Can you post pics of the connectors you have or a list of what doesn't work?
8,371
Welcome to TRS :)
Good page to Bookmark here: https://www.therangerstation.com/tech/
This is our Tech Library section, has lots of "been there/done that" articles on Rangers
Click on the "Engines & Fuel" section
Scroll down to "V6 engine swaps" there will be a few articles on the wiring for these swaps
Rangers and Bronco II's(B2's) have pretty much the same wiring by year, so what applies to one applies to the other
Explorers can be different but very very similar
gaz
660
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
@hellgoat71 ,
I expect your issue is routing the Explorer's wire harness in the Ranger's chassis. The Explorer PCM is mounted in the cab, passenger side kick panel while the 2nd Gen Ranger PCM is on the driver's side and as I understand it, in the engine bay near the firewall. In other words they are laid out completely different.
SenorNoob
579
Middle Tennessee
245-70-R16
Explorer kept the ECU in the passenger footwell thru 94. Ranger changed in 93.
BlackBII
Ranger Custom
Truck of Month
982
UT
91 - 93 should be pretty close to plug and play if you swap the ecu harness, engine harness, and power distribution harness. You may have to swap a few wires on the large bulkhead plug on the drivers side firewall.
What isn't working?
89RanBrII
33
Newcastle, Wyoming
Ranger & BrII
Ranger: 2.9; BroncoII: 4.0
