1991 ford ranger
Dustin907
Arab alabama
Ford, ranger
I just bought a 1991 Ford ranger, most sensors have been replaced along with spark plugs and wires, it wont go above 3 grand in rpms, ive tried everything and need help
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
If your in park or neutral I think there is a limiter in effect. Try it in drive.
Dustin907
Arab alabama
Ford, ranger
It doesn't matter if it's in 1st gear or 2nd, and I'm noticing when I push the pedal down all the way I lose power and the motor bogs down
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Have you check the fuel pressure? It should be 30 to 40 psi. You can check the fuel pressure regulator for a busted diaphragm by pulling the vacuum hose and smelling for gas fumes or liquid. If so then replace it. Also wouldn't hurt to replace the fuel filter.
Dustin907
Arab alabama
Ford, ranger
I do know the fuel filter is brand new, doesn't seem clogged and I haven't checked the fuel pressure regulator will do that tomorrow thank you for your help will be updating,
Dustin907
Arab alabama
Ford, ranger
I checked all that and it came back good no idea what's going on
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Hmmm, long shot...have you checked the air filter housing for a mouse nest?
Dustin907
Arab alabama
Ford, ranger
Air filter is clean, got a brand new one in it, I am getting a code for my maf sensor tho, don't know if that will fix it but I'm gonna replace it when I get paid
Dustin907
Arab alabama
Ford, ranger
Changed maf sensor and cleaned out injectors with injector cleaner I have no change and no check engine light I'm out of ideas
