richard booth
- Mar 18, 2012
- 28
- Tacoma wa
- ford
- Engine Size
- 2.9 for now.
So I got a 1989 Bronco 2 that wasn't running andthe guy said he had the transmission rebuilt and after he drove it a while it quit and wouldn't start well he played with a ton of stuff, replaced the distributor and TFI module, the ignition switch and the neutral safety switch, and after I diagnosed a bad fuel pump relay we got it to start. Then get this it won't turn off? I tried replacing the ignition switch adjusting it every way possible, but even with it running and the switch off, moving it to the off position it would not turn off the engine? The wiring has been monkeyed with quite a bit, so any ideas what could be causing it not to turn off?
