Wanted 1987 ford ranger 2.3 Manual computer
Trentela
Arocronic1337!
Looking for a manual computer for my 1987 2wd 2.3 for a decent price
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
Not sure of comparability but I’ve got an 85 ranger 4x4 2.3 manual.
Trentela
Arocronic1337!
Mine is 2wd, can anyone chime in if that computer will work? How much?
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Doing s little searching I’m seeing 85 and 86 comparable but no mention of 87. If someone does chime in and say yes I’ll get back to you with a price. You have a part #
franklin2
1,758
Virginia
This info is from rockauto. You can see some of the computers match, but you will have to check the numbers on the computer.
1987 ranger 2.3 with manual trans.
-CARDONE 784226 {Click Info Button for Alternate/OEM Part Numbers} Remanufactured; Plug & Play - No Programming Required Info
Manual trans.; ID #(s) E5TF-AB, JA, JB
-BSE EM079 {Click Info Button for Alternate/OEM Part Numbers} Remanufactured; Plug & Play - No Programming Required Info
Manual trans.; OE No. E7TF-AA
-BSE EM7900 {Click Info Button for Alternate/OEM Part Numbers} Remanufactured; Plug & Play - No Programming Required Info
Manual trans.; OE No. E5TF-AB, JA, JB
-CARDONE 784307 {#E7TF12A650AA, E7TZ12A650AA} Remanufactured; Plug & Play - No Programming Required Info
One of our most popular parts
Manual trans.; ID #(s) E7TF-AA
1985 2.3 4x4 from rockuto.
-CARDONE 784323 {Click Info Button for Alternate/OEM Part Numbers} Remanufactured; Plug & Play - No Programming Required Info
Manual trans.; ID #(s) E5TF-DB, MA, MB (Only 1 Remaining)
-BSE EM323 {Click Info Button for Alternate/OEM Part Numbers} Remanufactured; Plug & Play - No Programming Required Info
Manual trans.; OE No. E5TF-DB, MA, MB
Trentela
Arocronic1337!
I don’t know which one i need though cause i manual swapped my 87 2.3 ranger, what is the difference between the computers?
2 bronco 11s
66
kentucky
ford bronco 11
Did a check on all sensors and injectors. All but the O2 sensor and TPS sensor are the same. I would use them out of your engine and stick with the computer for your truck. I have had good luck with Cardone. Hope this helps. Auto zone has a good site to tell you what parts fit, what years and what engines.
Trentela
Arocronic1337!
There is 2 different cardone manual computers, the donor truck was a 2.0 manual
2 bronco 11s
66
kentucky
ford bronco 11
You have a 85 that was a 2.3 and now you have a 87 2.0 in it?
Trentela
Arocronic1337!
No I have an 87 2.3 efi that had the a4ld, that i switched to a tk5 manual out of an 87 2.0 carbed
2 bronco 11s
66
kentucky
ford bronco 11
Use a Federal Emissions computer for a manual trans for the 2.3. On the 1988 and 1990 I changed to manual the difference in the 2 computers on those were Federal versus California emissions.
2 bronco 11s
66
kentucky
ford bronco 11
You need to get the computer that the first 4 letters and numbers match yours. E5TF is actually a 85 computer which was still used in 87. E is for the 1980 year. The 5 stands for 1985. The E7TF is 1987. They changed the programing. 1990 would be F0 for 1990 and so on. These are programmed for an auto or manual. They are not listing Federal or California emissions for these.
