1986 2.9 EGR delete. Need correct1988 ECU P/N
Adobomb
Olympia Wa
Hello, my dad and I just bought a 1986 Ranger 2.9 manaul with 4wd. Someone before use removed and capped EGR valve from manifold and intake. We got it running pretty good but we need a 1988 ECU to get the fuel ratio correct. Would you reccomend using a aftermarket ECU or going with OEM ECU? Also can anyone tell me what the correct OEM ECU part number that i need to look for the 5 speed 2.9? Thanks
rusty ol ranger
2.9 Mafia-Don
7,578
Michigan
177 CID
88-92 5speed 2.9 ECM with federal emissions.
Adobomb
Olympia Wa
Thanks! There is a difference in ECU p/n's between manual 5 speed and auto. Also, is'nt it not the P/N thats important I think but a different code printed on ECU for the software load. Anyone have anymore info on this?
rusty ol ranger
2.9 Mafia-Don
7,578
Michigan
177 CID
You should be fine as long as its a 88-92 5sp with federal emission. I dont know the part number difference between auto and manual but wherever you buy from should describe it as "auto" or "manual".
I dont *think* the software number really matters a whole lot on these older trucks because the ECM basically just runs the engine.
franklin2
1,767
Virginia
If you go to rockuto.com and look up a 1988 Ford Ranger and pick a 2.9 v6, and then search for engine computer, their listings have all the factory numbers. Check the other years also and write their numbers down.
2 bronco 11s
66
kentucky
ford bronco 11
1988 2.9 manual no egr. E8TF-12A650-P1A. 89-92 are the same. Probably can an locate the Cardone part number in my other Grandsons if you can't cross it over. Haven't had any problems with the Cardone since I switched it to manual.
