MasonDaniel7
- Apr 4, 2018
- 191
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Another classic ruined.
Dude cmon. This things on a different level. Atlrast you kept the factory chassis so in theory it could be put back original.
Actually... This is exactly what I’m doing. I’m looking for a newer Superduty chassis to put my ‘79 body on. I don’t plan on changing much of anything on the body. I plan on modifying the chassis to fit the body. I just want 4wd with better handling and ride.Dude cmon. This things on a different level. Atlrast you kept the factory chassis so in theory it could be put back original.
Ive never had an issue with the chassis. They perform just fine as a truck.Actually... This is exactly what I’m doing. I’m looking for a newer Superduty chassis to put my ‘79 body on. I don’t plan on changing much of anything on the body. I plan on modifying the chassis to fit the body. I just want 4wd with better handling and ride.
From the looks of this, he did the same thing only with a car chassis. I think the 73-79 body was the nicest looking trucks ford designed, but there’s room for improvement on the chassis.
That doesn’t mean there isn’t tons of room for improvement... that just means you find it acceptable. You can’t honestly tell me that a 70’s F250 and a 2012 F250 ride, handle, or perform anywhere near the same. I know for a fact that the newer truck can out accelerate, out brake, and pretty much out do a 70’s truck in every category except style.Ive never had an issue with the chassis. They perform just fine as a truck.
Out accelerate? A hopped up 460, 4 speed, and a set of 4.10s against a 6.2L im saying the 460 is gonna take it.That doesn’t mean there isn’t tons of room for improvement... that just means you find it acceptable. You can’t honestly tell me that a 70’s F250 and a 2012 F250 ride, handle, or perform anywhere near the same. I know for a fact that the newer truck can out accelerate, out brake, and pretty much out do a 70’s truck in every category except style.
I prefer old steel with a new feel.
Believe whatever you want...Out accelerate? A hopped up 460, 4 speed, and a set of 4.10s against a 6.2L im saying the 460 is gonna take it.
Braking? Start stopping sooner. Pretty easy. Stuff ran out infront of people in the 70s too. Something tells me that assuming the braking system on the dentside is in good working order the difference here wouldnt be as much as you think.
Towing the 2012 has an advantage, but once again a hopped up 460 isnt going to have an issue in the power dept and trailer brakes have come a long way. Id also be willing to bet actual payload capacity is also pretty close when you figure in the 70s truck being considerably lighter then the superduty.
Later 70s Disc/drum combos stopped damn good.Believe whatever you want...
Compare a a “hopped up 460” to a stock 6.2l so you can live in your 1970s fantasy world. Keep imagining that 1975 drum brakes are as good as 2012 disc brakes.
A newer Superduty stops better. Enough that my 66 year old neighbor, who claims to drive like “a little old lady when he’s towing his Bobcat”, tells me there’s a world a difference between his ‘79 f350 and his ‘99 f350.Later 70s Disc/drum combos stopped damn good.
A stock 6.2 is what...400ish ftlbs in 2012? A carbed STOCK 460 was in the 380 range. It wouldnt take much.
You might beat it on the highway...but if youre towing the kinda weight it would take to make either engine snort 55-60 is the fastest you shoild be going anyway.
Not enough to justify ripping apart a late 70s 3/4 ton just to mount it on the SD chassis. Unless the 70s truck is rotted underneath.A newer Superduty stops better. Enough that my 66 year old neighbor, who claims to drive like “a little old lady when he’s towing his Bobcat”, tells me there’s a world a difference between his ‘79 f350 and his ‘99 f350.
So stock vs stock the 6.2 is a little better?
Glad we agree.
Does it really matter???Not enough to justify ripping apart a late 70s 3/4 ton just to mount it on the SD chassis. Unless the 70s truck is rotted underneath.
If not sell it to someone who'll apperciate it and just buy a damn superduty instead of bastardizing something that get more scarce everyday.
