08 FX4 SAS
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Got some explorer leafs. The plan for now is to install those and remove the factory lift block.
1996xlt
23
NC
Getting ready to do the same to mine, but having trouble finding a properly sized center pin....good luck!
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Ya i couldnt find em either. I read that you can just take long grade 8 bolts of the same diameter, grind the heads till theyre round, then install them and cut off the excess length. Luckily the ones on my explorer leafs are in good shape. Im just gonna flip and reuse.
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Explorer leafs are in! Removed the factory 1.25" lift blocks and I still gained 1 inch in height.
1996xlt
23
NC
Looks good! How does it ride?
Btw I did find the correct center pin (7/16") after visiting a local spring shop.
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Rides pretty good. Little stiffer than before but doesnt bother me.
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Did my hitch last night. Raised three inches for the body lift. Bolted for now but im gonna have it welded when i get a chance. Pics soon
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Welded & Painted
Mounted
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Got a Canoe! :yahoo:
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Did some dirt biking then went and got my truck real stuck. Probably shouldnt have attempted this hole in 2wd with the bikes in the back haha. Luckily the local Ranger guys were able to come help :icon_thumby:
UltraHDGames
Manitoba, Canada
Fx4 Level 2
2" Crank, Shackles, AAL Bilstein 5100s
285/75r16
Wow you got a bad ass truck! Keep it up
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Had a meetup with some guys in the BC Ranger Club. This is a first for us in the Okanagan area. Went well but we need to recruit more members. Beautiful view, great weather, and friendly people :icon_thumby: Knox Mtn Park, Kelowna BC Canada
