'04 2WD Edge - why is it so high?
8thTon
--- Banned ---
806
Pennsylvania
My world is filled with stuff that needs to be fixed
Can someone explain why they raised the 2WD version? I got the truck because it was in nice shape and the price was decent, but it will be used to haul stuff for projects and share commuting duty with my car. I like the sway bars, 10" drums, 4.10 rear 235/75R15 tires, but why block the rear springs? Was it required to clear the torsion spring mounting?
It's a bit of a PITA for loading stuff, and raises the center of gravity for no purpose.
The Edges were built on the 4x4 suspension regardless of 2wd or 4x4. It was just part of the appearance package having that 4x4 ride height, for people who wanted the height, but not the 4x4.
RangerVet
34
Kingman, AZ
FordRanger Edge
From here on down it's uphill all the way!
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
On 2wd drives, it's for appearance only and makes the truck handle like ass. You can remove the rear blocks and lower the front with the torsion keys.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Looks like you could just remove the rear blocks and leave the front alone on that thing... Jeeesh
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
Second that ^.
The front is at a good height. Drop the rear end and it will look a lot better. You adjust the torsion bars to much then you are going to need an alignment.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,500
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
First off... that truck looks clean.
Secondly... I would embrace it. A little twist on the torsions to level it a bit and a set of 31x10.50x15's. Align it up and drive on.
8thTon
--- Banned ---
806
Pennsylvania
I did notice the shorter U-bolts are pretty cheap on RockAuto. It seems like it would be level just removing the blocks at the back, without any detrimental effects on load capacity or handling.
Surprisingly the truck handles pretty well as-is.
31's would look cool, and the higher final drive ratio would help mileage, but the speedometer error would make me nuts (lol). Plus 235/75-15's are the most common tire, and the ones that are on it are brand new.
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
I removed the blocks from mine, and the front was a little high. Lowered the front about 1" and it leveled to my liking. to each his own, some people like the nose to be a tad taller than the rear, why, IDK. I have basically the same truck, but an '01 and it's white. It handled better for me after lowering it, also this truck pulled a trailer better than my "08 Sport Trac.
Edit: my truck has a 3.0/5spd with 3.73
8thTon
--- Banned ---
806
Pennsylvania
Cool, thanks for that advice - it's helpful to know someone has done it. I'm seriously considering it as I just see no benefit of having it that high. I have not even begun using it to haul stuff and I have no doubt the liftover height will become annoying quickly.
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
Can't believe no "Snoop Dogg" or "Willie Nelson" Jokes came from the question, "Why is it so High?"
Danno1985
105
MKE, WI
stock
stock
stock
This seems like one of those good problems to have. Stance on that truck is perfect, even with the 235/75r15s. I'd rather have rake unloaded than having a "leveled" empty truck that looks like a lowrider any time it's hauling anything, but that's just me.
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
If his was anything like mine, it looks a little silly sitting so high in the back, it's about a 3" difference front to back. Having the nose 3" lower than the rear is just too much, but like I said before, To each his own.
8thTon
--- Banned ---
806
Pennsylvania
I agree. My old 2WD 1990 long bed Ranger could haul a pretty impressive load, and even loaded up with bags of mortar it sat pretty level. I'll have to measure the suspension travel but I bet even if you squashed this on down on the bump stops it would still be nose down.
