03 level 2 tire size
bcost882
U.S. Military - Active
5
The Queens Country.....
3.0L, 1.6L
with a t-bar crank you can get 31s
07rangerfx4lv2
Ontario, Can.
ford ranger
4.0l
31's are stock, you can fit 32s after a t-bar crank
Irokranger93
Michigan
3.0L
http://www.rangerpowersports.com forum
Posted by Redneckstone
01-08
XLT 4X4, FX4, Level II, EDGE 2wd & 4X4(Sport newer models)(mild T-bar crank always recommended for leveling purposes, always remember to get an alignment)
* 15x7 stock suspension - 30x9.5x15, 31x10.5x15, 32x11.5x15, 33x10.5x15(T-bar crank recommended), 33x12.5x15(will need trimming and T-Bar crank)
* 15x8 stock suspension - 31x10.5x15, 32x11.5x15, 33x10.5x15(T-bar crank recommended), 33x12.5x15(will need trimming and T-Bar crank)
* 15x8 & 15x10 body lift or suspension lift - 32x11.5x15, 33x10.5x15, 33x12.5x15, 35x12.5x15(trimming also involved in multiple areas and T-bar max...), 325x60x15(31x12.9x15)
* 15x8 & 15x10 body lift AND 4-5" suspension lift - 33x12.5x15, 35x12.5x15(T-bar crank recommended, were applicable), *Anything larger at your own risk or T-bar max and trimming*
* 16x7 stock suspension - 255x70x16, 265x70x16, 265x75x16, 285x75x16(mild t-bar crank recommended but might not be needed.)
* 16x8 stock suspension - 265x75x16, 285x75x16(same as above) 295x75x16(t-bar crank recommended and maybe trim.)
* 16x8 or 16x10 body lift or suspension lift - 265x75x16(16x8 only), 285x75x16, 305x75x16, 315x75x16(trimming also involved in multiple areas and T-bar max...)
* 16x8 or 16x10 body lift AND 4-5" suspension lift - 285x75x16, 305x75x16, 315x75x16(T-bar crank recommended, were applicable), *Anything larger at your own risk or T-bar max and trimming*
____________________
01-08
XLT & XL 2wd
* 15x7 stock suspension - 215x75x15, 235x75x15, 235x60x15, 30x9.5x15, 31x10.5x15(may need to trim)
_____________________
98-00
XLT & XL & Sport 2wd
______________________
98-00
XLT 4x4, XLT Offroad, Trailhead(mild T-bar crank always recommended for leveling purposes, always remeber to get an alignment)(may want to also replace T-bars do to T-bar sag)
* 15x7 stock suspension - 30x9.5x15, 31x10.5x15, 32x11.5x15, 33x10.5x15(T-bar crank recommended), 33x12.5x15(will need trimming and T-Bar max)
* 15x8 stock suspension - 31x10.5x15, 32x11.5x15, 33x10.5x15(T-bar crank recommended), 33x12.5x15(will need trimming and T-Bar max)
* 16x7 stock suspension - 255x70x16, 265x70x16, 265x75x16, 285x75x16(mild T-bar crank recommended but might not be needed.)
* 16x8 stock suspension - 265x75x16, 285x75x16(same as above) 295x75x16(T-bar crank recommended and maybe trim.)
93-97 (Consult before adding tires, this is the tricky year)(may also need lift in rear depending on spring sag)
4x4 & 2WD (The 2wd and 4x4 front springs are the length and the shocks.)
* 15x7 stock suspension - 30x9.5x15, 31x10.5x15(may need to trim valance a little, if major spring sag wont fit)
* 16x7 stock suspension - 235x60x16, 235x75x16, 245x75x16(slight chance of trimming)
* 15x7 & 15x8 Leveling block or leveling spring - 31x10.5x15, 32x11.5x15( may need major trimming)
* 15x7 & 15x8 Leveling block or leveling spring & BODY lift or suspension lift - 31x10.5x15, 32x11.5x15, 33x10.5x15, 33x12.5x15(may need minor trimming)
* 15x8 & 15x10 body lift AND 6" suspension lift - 33x12.5x15, 35x12.5x15, *Anything larger at your own risk*
* 16x7 & 16x8 Leveling block or leveling spring - 245x75x16, 255x70x16, 265x70x16, 265x75x16(will need trimming with 16x8)
* 16x7 & 16x8 Leveling block or leveling spring & BODY lift or suspension lift - 265x75x16, 285x75x16(may need trimming), 305x75x16(may need trimming)
* 16x8 or 16x10 body lift AND 6" suspension lift - 285x75x16, 305x75x16, 315x75x16, *Anything larger at your own risk*
bcost882
5
3.0L, 1.6L
my bad i didn't see the level 2. eh. thats a useful chart there
