03 2.3L bog in OD
kschaffner
Hello, I was just reading some posts about a bad torque converter. I myself am not positive that it is the cause of my problem but I am running out of things to check/replace :p
My problem is when I am driving my 2003 Ford Ranger XL 2.3l with the 5R44E tranny when it shifts into OD, it has this bog feeling between 45 and 60 mph only. If I am below or above those speeds in OD its perfectly fine. If I take the tranny out of OD it will run perfectly fine at those speeds as well.
I have replaced the following: TPS, Fuel Filter, Plugs and wires, transmission filter & fluid, replaced air filter, and cleaned the MAF.
If you have any insight to this problem it would be greatly appreciated.
Thanks!
kschaffner
Anyone at all?
ES894x4
December 2013 STOTM
MTOTM Winner
5
45 mph in over drive with a 4cyl sounds like cruel and unusual punishment. where are your rpms at when you feel like its bogging if below 2500 then you are indeed bogging your motor.
kschaffner
I want to say that they are around 2k but I will find out for sure. Should I just take it out of OD or could it be something else? I do notice that it is worse on hills and sometimes curves, specifically on/off ramps
press 1 for english
8
Arcadia, Fl
2.3
The engine shouldn't be bogging, the tranny should be downshifting on it's own to avoid that. With my 4 banger and the auto, it'll downshift quite a bit and it never bogs. The5 spd auto tranny we have works best with the 3.0 and 4.0.
