Welcome to TRS
2 and 6 share a coil in the coil pack, so I would start there, its possible you have burnt exhaust valves but 2 and 6 do have the coil in common
Coil pack only has 3 coils inside, each coil sparks 2 cylinders when they are both at TDC(top dead center), called a Waste Spark system, uses Crank timing unlike a distributor that used Cam timing
Coil wiring looks like this
[3 4]
[2 6]
[1 5]
So 1 2 3 side and then 5 6 4 side, 1/5, 2/6, 3/4 these Pairs spark at the same time
Those are the Match Pairs of how the V6 engine is balanced, 2 cylinders at TDC every 120deg of rotation, balanced rotation
It can go this way as well, don't get hung up on direction its the Matched Pairs that matter
[1 5]
[2 6]
[3 4]
If you have a 12v test light you can test if computer is "sparking" all 3 coils
Unplug the 4 wire connector on coil pack
One wire will be red/green, that wire has 12volts with key on, powers all 3 coils in the pack
The other 3 wires go to the computer
Tan/and different color stripe for each
Test light goes to red and one of the tan wires
Crank engine over, test light should flash on and off, if so computer is working on that one tan wire
Test the next tan wire
No flashing means that tan wire is disconnected OR computer transistor(circuit) is bad
Pins 26, 52 and 78 are the 3 tan wires on computer connector
