Ravo's Ranger
cleaned up my wheels with some sos pads and mothers chrome cleaner. 10x better. now i just need a power ball/cone and some polishing compound
came home from school and saw this box sitting on the counter. yahoo!
should be getting everything back together tonight. hopefully get it registered thursday. then i can have fun with it
2" levelling coils right? i forget.. if you can swing it id throw some washers in while your at it. i did with mine and it worked out nice but i did have the camber correction whatevers in my truck too. worst coems to worst the fronts higher and you throw a bigger block in the back :icon_thumby:
yup 2" coils. should be more than enough to clear my 32's as they almost clear now
just a couple other pics
got the arms painted up black. look a heck of a lot better and less grimey
some more ford blue and got the driveshaft hooked up
put some brand new grease fittings all over the place. i get the feeling she was abused and neglected
and i got my coils mounted up. i love new parts
should have everything finished up by thursday... it should be tomorrow but i'm working....again
this is a really good thread
got 3 wheels mounted up. still need to swap out the coil on the right side, then i can finish her up..
i think the tires fill the wheel well nicely
just barely sticks out in the rear
untill i get an alignment and my coils settle i have terrible camber problems. lol
ahhh the joys of TTB....
made some homemade stud extenders. work great.
i love the stance of this truck. i'm glad she is mine.
also.... her name is brutus
also. the springs have already settled a bit so the camber isnt as bad
well i'm getting her registered in the a.m. i still need to get the inner fender and fender flare on so she is still a little camera shy. also i need to check all my fluids. seeing as the front dif had only a few drops i'm not to hopefull for the rear
very nice build not many teenagers have the drive to buy something that needs work done to it, I commend you on your work :icon_cheers:
X2
I'm a teenager and my truck needs work, unfortunately I owe lotsa money on it, so its hard to fix the truck up
Event Coverage
TRS Merch
