do a google search for the Taurus efan.....400+ HP cars/trucks are running the Taurus fan with no problems at all.....if 4500 CFM isn't enough to cool a Ranger's engine (or any other engine that you can put in a Ranger), then there is other problems....
the Taurus efan has the built in shroud which is the same size as the 4.0 Rangers radiators..........
back up my facts? I installed the Taurus fan on my '97 Ranger i had.....it worked without problems, cooled my truck better than the stock mechanical fan ever thought about cooling it, and the A/C worked amazingly better with the Taurus efan than the mechanical fan......yea and you can shut the fan down with the A/C running if you are at highway speeds....
BTW: this is a Ranger forums, not a diesel forum....he was asking about his Ranger, not his diesel........and i think a Taurus efan would do good on a diesel....it still pulls as much air as a stock mechanical fan on the diesels.....only limitation would be the diesel radiator is larger than the Taurus efan shroud......
