Can I copy or steal your idea on the Rear end Cover, I think that is so cool looking.
Robert
sure robert, you can borrow the cover design. i was actually inspired to make it after seeing plumcrazy's (i think?) pumpkin face cover, so it was kind of original but not entirely.
I looked for the pumpkin face cover, but i couldnt find the build thread on it. i believe it was on plums purple ranger, the one he had before the badass blue one. it was basically a cover painted orange with 3 black triangles for the eyes and nose and then a black mouth with square teeth, just like the classic jack o lantern look. on a side note, does anyone know where there is a good article on setting up the moog adjustable camber bushings? the shop i used to use just lost their alignment guy to the GM tech center, so that means i no longer have someone i trust to align my truck properly.
thanks pete, i just wish i had 4wd so that i could set up the the camber with a degree wheel like the one tech article showed. ive already got the moog K80109 adjustable camber bushings, im just not sure where i need to adjust them to. as it sits right now i can visually see that i have too much positive camber so i thought about pulling the existing bushings out and wire wheeling them to expose the # thats on them and then set the adjustables -1 degree from the existing bushing and then see where that puts me, then if i need to go another degree or so? i dont want to change my caster as it was in spec before the leveling, but i also am not sure how much the installation if the spacers would have affected it.
