- Jul 7, 2009
- Loganville GA
I didnt get time last night to reply, but i was going to tell you that the opperation of the fpr sounds correct. I belive the way that they are setup is, is under vac, the fpr is off, and as you rev, and vac is reduced, the fpr opens up, and adds pressure and fuel into the loop.
The best way to explain would be on an older carborated car. Take a car with a big vacume leak, and it runs rough at idle, and prob smokes, and is running rich. But take it up the road, and hold it wide open, it starts to clean up and run right (better). Reason being, its finnaly using enough fuel to catch up, and clean itself out. The same basic idea (I belive) happens in an efi motor. I know the way the egr valves work the same way too. With full vacume, the valve is close, and not allowing gasses through, and with it open (no vac) it is letting exhaust back into the intake.
Lol, out of time for a few mins, ill get to the ideas later. Un-fortunatly unless the fpr was just running sluggish with that stuff in it, it prob wont fix your issue. Have you checked the fuel filter itself??
The fuel pump is new along with the filter.. Last time it ran Rich it was the FPR... I am hoping the crud let more fuel by than needed.. Oh the injectors are all closing.. It held a lot of pressure after about 15 min of sitting.. Thanks for all the info and help!!
