- Aug 11, 2007
- Age
- 70
- Ontario, Canada
- My credo
- Love Thy Neighbor
lol
I'm going to pull off the belts again and look for a notch in the pulley. I'll try and mark it with some paint. I heard there should be one there.
My dad used nail polish...pink, actually...it shows up pretty good under the timing light...
But you should only have a V groove on the crank pulley...that's all that was ever on mine...and I usually matched that with the ^ on the aux shaft...and then made sure the cam pulley ^ is aligned with the center peg on the cam timing thingy...it's just a plastic piece with three ^^^ on it...and it should be part of the plastic shield for the back side of the timing belt cover...
Once all three of those are aligned and you make sure the pistons are TDC on the compression stroke you should be good to go...
To find the compression stroke, pull number one plug and rotate the crank...put your thumb over the plug hole and when you feel upward pressure against your thumb you are on the compression stroke...it also helps to pull the distributor cap and watch for it to align with the number one spark plug wire...
No, don't give up on it...flush the rad for sure...or a complete system flush would be better because crud accumulates in the heads after time unless you've had it flushed recently...and check the intake passages because there should be a hose going into that and that area is where I found quite a bit of buildup of sludge...
