- Aug 11, 2007
Allan, the inner only goes to 16 in/lbs, not 35...
someone needs to read the WHOLE thing before commenting ....
Tighten the inner nut and the inner nut ONLY to 35ft/lb and rotate the rotor several revolutions
Then back the nut off and retighten to 35INCH/lbs
Install the perforated washer and thread on the outer nut.
the OUTER nut get tightened as tight as you can make it
225-250ft/lb IS entirely reasonable.
That OUTER nut isn't tightening the bearing
it's only squeezing the washer agaisnt the inner nut and LOCKING
the two nuts and the washer together.
The inner nut is the "adjustment" nut
the outer nut is a "jam" nut
My "big" torque wrench is 36" long and 3/4 drive and
225ft/lb isn't even half scale on it
But oddly the scale is marked in inch pounds
it's strange to torque something to 7200in/lbs
AD
there is NO WAY to tighten the INNER bearing. It is held on by the nut holding the outer bearing.
I'm just telling you what Alldata gave me for your vehicle with manual hubs.
I wasn't talking about the pre-load, I know that's 35 Ft-lbs, I was talking about it's final torque after it's been pre-loaded.Loosen inner wheel bearing locknut using a suitable spanner wrench, then torque locknut to 35 ft lb .
Loosen inner locknut 1/4 turn, retighten to 16 inch lbs ., then install lockwasher on spindle. If necessary, rotate locknut slightly to align pin with closest hole in lockwasher
I agree! I usually convert the in/lb to ft/lb when the manual calls for in/lb.You guys rock. I've never seen so many people with in/lb torque wrenches.
I only have a ft/lb torque wrench.
This is the way I set mine up. I have had my inner nut be lose with 25 ft/lb on it.I tighten the inner up to 35 ft/lb, back it off a 1/4 to 1/2 turn and then snug it back up. I tighten the outer nut as tight as I can get it and then spin the rotor just to make sure there isn't to much drag on it.
