- Apr 17, 2025
- N/A
- State - Country
- TN - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 3.0L
- Automatic
- Total Lift
- 2”
- Tire Size
- 15”
Bit of back story here. On my 99 ranger every time I go over 63 miles per hour it starts to vibrate violently, I assumed a wheel bearing and sure enough I checked the play and it was very loose. I went to get a hub when I found out those were only for the 4x4 versions, and I found out the front wheels have regular hubs on them. I opened it up and tightened the nut, incorrectly setting the castle nut locker, so it backed off later. I retightened them so that they have a small amount of pretension this time correctly placing the castle but so it was tight against the cotter pin, but sure enough it continued to vibrate. I’ve been told you shouldn’t have pretension on your wheel bearings, but I think it needs some, how much is too much?
Not sure if this is the correct sub-forum, but I’m sure someone will see it.
