- Jan 5, 2009
- Titusville, FL
so im lookin at 187.60 total for everything exept the box. which will be another 20 dollars or so, right? which will make the total to 207.60.
the amp wiring kt has a 30 amp fuse. should i replace it with a 25?
yes if something goes wrong you want the wiring kit to be the weak point not the amp.
actually the weak point would be the 8ga wire, if it shorts out it will get very hot and melt if your fuse is too big for the wire.
