Kicker Truck Box Worth The Money?
so im lookin at 187.60 total for everything exept the box. which will be another 20 dollars or so, right? which will make the total to 207.60.
a full sheet of mdf will prolly be 25-28 but yea. as far as the total.....um sure lol idk were you got it all from.
stealbay :) i love shoppin online for the good prices. Are these good prices?
VISONIK V308XT 800 WATT 2 CHANNEL AMPLIFIER CAR AMP- 74.90 shipped
8 gauge, 800 Watt Amp Wiring Kit- 20 shipped
KICKER CVT-124 CAR SPEAKER SUBWOOFER/SUB WOOFER COMP 12 -87.70 shipped
And everything is 4-ohm :)
also, your amp has as 25amp fuse, make sure your wiring kit has a 25 or even a 20 amp fuse in it.
the amp wiring kt has a 30 amp fuse. should i replace it with a 25?
yes if something goes wrong you want the wiring kit to be the weak point not the amp.
actually the weak point would be the 8ga wire, if it shorts out it will get very hot and melt if your fuse is too big for the wire.
id definetly go with at least 4ga if you plan on going bigger down the line. even if you dont bigger wire has less resistance per foot which equals less wasted voltage from battery to amp.
i know it seems like a extra money you have to spend by buying a wiring kit with a larger capacity. but for the non ebayers they can get expensive if you have to keep upgrading. not to mentiong the slight pita factor of re running your wiring. so what i did was, i ran a 0 gage wiring kit, ( but 2 or 4 may be big enuff for you) so no matter your set up you will always have a big enuff wiring kit. i also got a bunch of different size fuses, from like 40amps to 120 amps. that way when your system changes you just have to change the fuse. not every wire
