Kicker Truck Box Worth The Money?
NOW THAT! sounds like a plan! How much extra board ,Money wise, do you think that will cost?
I want a 12 so i can hit good in the lower 30's and 20's.
well you can buy mdf in 4x4 sheets, but you may have enough left over to do it, even if its two pieces its ok, it just there to take up space.
i was talking about the re series not the sl series.
i have the RE's-RE series 8" and it hits 25htz really hard taking it to get metered next week.
missed that one lol,
also, i would step up to 3/4 mdf. if you can with the $$$ it not much more, and it will stronger, and easer to put together, trying to put a screw in half inch mdf will be a nightmare
well i found "1X6X8 PRIMED MDF BOARD" at my local lowes for 7 dollars... is this what i need?
EDIT: or am i just stupid and thats inches?
lol no that a type of molding, im pretty sure. but i cant even find you a pic to show you wtf
it looks like a 4'x8'' sheet of really thick cardbord
:D oh well then why dont they just say "4X8 sheet of really thick cardboard" then...
*sigh* well i just looked at prices for carpeting and i cried ( just kidding) but why does "speaker box carpeting" cost so much? is there a substitute for this stuff?
good, but thin indoor out door carpet
or like 5 or 6 thick coats or primer.... airbrush can of your color, flames pin striping, same color as your truck, a lil wet sanding some clear, and one bad ass box.
heh. i dont have time for that much detailing.
On a side not i found an amp wiring kit 10 ga 14 dollars shipped. Should i go bigger than 10 Ga?
oh, and also, i want to get a visonik v308xt amp bridge it to 800 watts peak at 4-ohm. sound like a good amp? Should i use a cap with this system to reduce fading lights?
no need your rms with that amp is 360w, so your ok. 10g might be a lil small but check the specs for running amps for the kit, as long as it can handle 360w its ok
