Getting the Ranger turbo ready. Need driveshaft tips.
Featured Build Threads
bathtub.toaster
Forum Member
Tifton, GA
I'm currently building a track-oriented '97 Ranger 2.3L 5-speed that I've done a lot of work to over the past 3 years. Lowered it, stiffened the suspension, swapped over to manual steering, freshened up steering linkages, swapped to an 8.8 rear end. I've done a lot more all around, but that's pretty much the gist.
Now, I've been wanting to go forced induction for a while, but it would have realistically been way out of my budget to rebuild the current engine to get it ready for that. So I did what any sensible guy would do and went on Marketplace. Originally looking for an SVO, or a Thunderbird as a donor, I quickly found that small turbo engines were not at all popular in my area, only finding 5.0s and supercharged 3.8s. Just as I was beginning to lose hope, I came across a PowerNation video about building a 2.3L dirt track racing engine. That's when I realized... There's dirt tracks literally everywhere near me! So I went snooping around on local fb groups, and sure enough, I found someone selling a fully built engine for $1500 (picture below)! After that, the build was back on track. Scored a T3/T4 Turbo, then the exhaust manifold, intercooler, and all the other odds and ends I needed to get the turbo installed. I currently have the engine broken down and at a shop getting decked. So while that's away, I figured I'd ask anyone that knows on here for a good recommendation for a driveshaft and any tips on keeping it from vibrating itself to oblivion. My budget for it is around $200-$400 and I have the long bed single-cab ranger. My hp goal is around 400-500hp.
Edit: In case anyone was wondering, I also have a T5 trans ready to go once I get the engine back together.
  • Getting the Ranger turbo ready. Need driveshaft tips.
You have a big place in Georgia called the driveline shop. Do not know how close they are to you, but they should be able to modify or build what you need. If you have a old one laying around that they can shorten it may be cheaper. If your rear gear is 4 something or higher, should not need a very large diameter driveshaft. You will want it to be light so the truck gains rpms as quick as it can. A heavy driveshaft acts like a flywheel.
I know one problem you might run into, they made a special clutch for the SVO I had. When you make a lot of power with these engines, it's hard to fit a large enough clutch in the smaller bellhousing those engines came with.
Here's a link to that shop in Ga https://www.thedrivelineshop.net/
I can definitely source a decent driveshaft from the junkyard if that's the case.
As for the clutch, how much would something like that go for?
Upcoming TRS Events
Featured Ranger Based Vehicle
