Arkansas ranger owner.
Featured Build Threads
80s Nissan Hardbody shocks used to be the lowered Ranger go to… Or Squarebody C10 front shocks as rears for a Ranger with an axle flip…
I’ve done a rear shackle flip on my 94 rcsb 2wd. Going to use the Gabriel Load Assists off the front of my wife’s 85 C10 swb lowrider project. Also added a pair of 500#/ea overload half leaves. Even a 2.3 can get the rear axle doing the boogity boogity if your truck has 2+1 instead of 3+1 or 4+1 rear springs.
You might ask a mod to move your thread to the 2wd build section. This looks like it’s well worth following.
Shake down passed. 318k and counting.
I need to. This is just getting started.
Did the 02's. Ran it another 30 minutes. Looks ready. Got rust converter coming. New fill hose.
You can rob the connector out of your stock radio. Nice spades to solder your plug to. No cutting or ruining anything. I covered the connections in rubber adhesive. Keep.the sparks in.
What a difference huh? 2 in one converter. Big bucket. 141oz. My rust was just fluff mostly. Wire brush, paint it on. It cleans with water and it does.
You need these. The soft round and a drill motor will get 80%. The small brass gets the rest. The kit comes with a couple brushes but youll need a smaller one too.
Gas tank had to come down. The crap in the protection plate under the tank. Rear trans seal is leaking id bet.
Crazy how this stuff makes it look new again. Second coat on most of it. It's a lot of work but worth it.
Upcoming TRS Events
Featured Ranger Based Vehicle
