4.0L SOHC Pulling the SOHC for inspection
Featured Build Threads
I’m gonna drive myself crazy. I can’t find the 4 motor mount nuts. I should have 8 bc I took two engines out; I have 1, and 2 are on the other ranger holding down the block so I could use those but where the heck are the other 5!?!
I picked up some 12x1.75 and 14x2.0 nuts and those don’t fit…
I have the same problem every time I do a major project. When I inevitably end up at the junkyard, I take all the hardware I can get.
So I knew this was crazy. I put all the bolts and parts I could in ziplock bags and labeled them. Turns out I put a bunch of those in a tote on top of the cab of the ranger… so it’s back to work today 😂
I'm going through the same fun of pulling the motor and i love the pics from teardown
I tried for nearly 5 hrs to get the motor back in, the dang spacer plate kept falling out, and I couldn’t get the engine/trans lined up. I decided to stop before I got stupid and did something dumb. lol I’ll try again tomorrow.
Glue the plate on with a couple dots of gasket maker?
Ah now that’s a good idea! I was looking for tape to tape it down and I could pull most of off after mating them up but electrical tape wouldn’t hold and neither would athletic tape and this was that he one time I couldn’t find any painters tape… lol.
I did almost have them together today. just couldn’t quite get em there.
Tried again today a little bit, couldn’t quite get it so I took the load leveler off and am just using chain, took out the motor mounts, disconnected the starter from the wiring and jiggled the exhaust back some more… I also cleaned up the plate and am trying the dots of black gasket maker to hold that plate on, it’s gonna dry overnight and I’ll try again tomorrow. I also spun the torque converter to make sure it was fully seated back. I’ll get it eventually. Hopefully next try.
Have you tried shaking it with all your weight and yelling bad words at it?
Only thing that's ever worked for me to be honest.
Once you start calling it a whore and threatening to murder it's family it should just pop right in.
This is next on the list. 😂
Upcoming TRS Events
Featured Ranger Based Vehicle
