Loud Bang, 4wd now dead
Featured Build Threads
Started it up and 2wl low light on solid.
Did you mean to say 4wheel low? I don't believe you have either a switch position or indicator light for 2 wheel low. 2wheel low is attained by selecting 4 wheel low with the front hubs unlocked and the 4 wheel low light should be on if that is the case.
I like 2wd low. But definitely no indicator for that. It's handy for hooking up trailers by yourself and using the front porch like a dock.
That's my favorite mode for rock crawling and slow trail riding.
Mine is in 2lo about as often as it is in 2hi lol, it is a very under rated option. I wish my F-150 could do it.
Unfortunately I agree with @pjtoledo, there is more to a t-case low range and rear output... especially if it is lazy at shifting and might have hung up in 4hi for a bit.
he said hubs unlocked...so 4 lo....just 2wd is what i got out of it. possible the chain popped. usually...that is fatal though.
Back at my cabin today, went into 4wl and climbed my hill twice, once with hubs locked. Seems fine.
On another note, my locking hubs seem to have lost whatever clips them in place. Ive read there is some weird tabs, can they be fixed or is there a better way?
That hold them on the hub when you remove the wheel?
Most pitch them and don't deal with them.
Yes, i can wiggle them and pop them off. Luckily i have those small hub caps on the alloy wheels so cant lose one.
Guess I misspoke earlier, I have no 2wl…
Chain? There is a chain in there?
Yes. The forward output shaft connects to the 4x4 stuff via a heavy-duty chain.
Hmm, chain. Still wondering what made that loud bang but since it pulled my cabin hill today in 4WL, both fronts pulling, must not be the chain. When that happened I was on level paved road in 2WH, about 40mph, not goosing it.. Front hubs were locked as usual, so front diff and shaft spinning. If one of those locking hups were to pop off, I guess the other side would keep the dif and shaft spinning. Don't remember that happening but when I pulled the hub cap off days later the hub was shakey loose as usual.
First post mentions a '99 not the '90 that's in his signature, just to point that out as I think you got that mixed up which makes sense.
As for what bound up, I would grab the rear driveline while in neutral with the parking brake on and give it a good shake at the rear axle...
I did, I was thinking the 90.
Upcoming TRS Events
Featured Ranger Based Vehicle
