- May 16, 2016
- Belton
- State - Country
- SC - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.5L
- Manual
- Tire Size
- 235/75/15
- My credo
- Don't get louder, improve your argument.
Evening folks!
I'm starting down the path to trying to figure out what is wrong with my '00 2.5L Ranger. I searched the forum and read all of the posts that have to do with this particular MIL code and have found a lot of useful ideas and symptoms that match what my truck is doing. I even consulted the Ranger tech section and will be using the O2 sensor article as a guide to help track this issue down. So far, research on The Ranger Station, BlueDriver OBD2 reader, and other forums point to the following possible issues:
I've pulled all the data I can from the BlueDriver reader and have listed it below. I'm sorry it's so long. I'm just trying to be as thorough as i can be. If you know much about sensor data, could you take a look? I'm planning on cleaning the MAF, checking the PCV and the hose, and cleaning the throttle body valve. I will also be running electrical reference tests on the O2 sensor and MAF. Unfortunately most of the to-do list relies on the next paycheck to come in, so it'll have to wait.
OBD2 Sensor Readings
BlueDriver with current firmware
2000 Ford Ranger 2.5L 4x2 @ 242,945 miles
Code: P1131 Lack of Upstream Heated Oxygen Sensor Switch – Sensor Indicates Lean – Bank No. 1.
Did have P0171 Code: System Too Lean Bank 1. Code has gone away.
Freeze Frame Report @ 242,800 miles
Mode6 Data attached - too much to type up. I don't understand it anyway.
If you made it this far, thank you! I'm hoping you guys can help me think of things i haven't thought of yet.
Mark
- Vacuum lines
- Intake manifold gaskets
- Mass air flow sensor
- PCV valve or cracked PCV valve hose/tube
- Clogged/Dirty throttle body valve
- Upstream O2 sensor
- Air leak between MAF and Throttle Body
- Oil dipstick unseated
- Leaking EGR gasket
- Stuck EGR valve
- Diaphragm or EGR Vacuum Regulator
- Exhaust leaks before upstream O2 sensor
- PCM - Engine computer
- Fuse issues
- Mass Air Flow Sensor
- Before Throttle Blip
- 0.5 - 0.6 lb/min (4.01 - 4.38 g/s)
- After Throttle Blip
- 0.4 - 0.5 lb/min (2.95 - 3.83 g/s)
- Key On Engine Off
- .1 lb/m (.55 g/s)
- Fuel System Status
- Open Loop due to detected system fault
- Closed Loop
- Key On Engine Off
- Open
- Bank One Sensor One Voltage
- 0.000v - 0.050v
- 0.025v - 0.780v
- Key On Engine Off
- 0.005v - 0.010v
- Short Term Fuel Trim
- Started at 3.1% - 8.6%.
- Changed to -17.2% - 42.2%
- Held steady at 0.0% for about 10+ minutes until throttle blip
- -92.2 (very briefly) - 9.4%
- Key On Engine Off
- 12.5% - 13.3%
- Long Term Fuel Trim
- 14.8% - 16.4%
- 14.1% - 15.6%
- Key On Engine Off
- 0.0%
- Other Readings
- Absolute Throttle Position
- 16.5%
- 16.5%
- Calculated Engine Load
- 28.6%
- 28.6%
- Intake Air Temperature
- 112°F
- 134°F
- Timing Advance Cyl 1
- 8.0° - 9.5°
- 7.5° - 12.5°
- Engine Idle Speed
- Between 948 - 970 RPM
- (02) DTC that caused freeze frame data - P1131 Lack of Upstream Heated Oxygen Sensor Switch – Sensor Indicates Lean – Bank No. 1
- (03) Fuel System Status Closed loop - using all oxygen sensor(s) as feedback for fuel control
- (04) Calculated Engine Load Value - 48.2 %
- (05) Engine Coolant Temperature - 170.6 °F
- (06) Short Term Fuel Trim Bank 1 - 42.2 %
- (07) Long Term Fuel Trim Bank 1 - 15.6 %
- (0C) Engine RPM - 2200 rpm
- (0D) Vehicle Speed - 46 MPH
Mark
