Featured Build Threads
Rick W, I suppose I am more or less asking what is the likelyhood that I have a faulty bearing, axleshaft or brake shoes causing the noise?
Ill def check and see if those specific wheel wobbles has shifted tires since the tire rotations.
Also I buy my tires used from discount shops :|
Look at the cheapest/easiest things first then move to the more expensive/harder to do stuff if cheap/easy doesn't work. It is possible you have a slipped belt in a tire or some other defect.
It is possible one of the parts you installed are bad as well.
As an example, I had a bent rim that I wasn't aware was bent until I rotated my tires and it got installed on the front axle. It felt perfectly normal while it was on the back.
Not today but yesterday, I had to work on my parking brakes on the 2011. The right side was binding up enough to heat the rotor. Quite annoying when I just replaced the rear pads and rotors a day ot two before. It turned out that the cam that actuates the brake shoes was binding. I got everything loose and working again, but I'll have to look at replacing those when I go to replace the shoes and the rest of the hardware. Access to the components on those brakes is not great to begin with. Throw in an even more rusted cam buried under the brakes shoes and the axle hub does not make for a good time.
You could have a warped wheel. It's happened to me before on other vehicles. Even stamped steel wheels can do this.
The only way to know for sure is to get each corner off the ground and start checking. If you don't find anything obvious, can always hit up a tire shop to check the balance.
I almost lit my kids Ranger on fire this weekend. He has a squeaky fan belt that I seem to fix. Although it's squeaking at the water pump, I replaced every pulley as well as the belt. Here's a list of what I have done.
  • Changed out all the pullies.
  • Changed out the belt at least 3 times. I am only using Gates belts.
  • Swapped out the AC compressor.
  • Swapped out the water pump with a Gates water pump.
  • Swapped out the belt tensioner for a Duralast unit.
  • Sand blasted the water pump pully.
  • Replaced the drive pulley.
  • flushed the cooling system
  • replaced the power steering pump and pully.
So, as you can see, replaced everything I can think of. Again, it is squeaking at the water pump. I found this out by using a mechanics stethoscope. Do you guys have any ideas? My next move would be to install a Gates DriveAlign belt tensioner.
25 years of potholes on steel rims, surely i have warped wheels!
I changed out my lumpiest of tires:
front pass had about 1/8in of up and down wobble
front driver had very little wobble
rear pass had bout 1/16 side to side wobble
rear driver had about 1/16 up and down wobble
well yeah, i swapped them out one by one and the 30mph 'wop wop wop' noise persisted, but i finally ended by swapping out that 1/8 wobble front pass tire and while the 30mph 'wop wop wop' was still noticeable, i took the truck to the highway and the pronounced 'wop wop wop' noise was no longer noticeable. i guess im good to drive this truck 1000 miles to idaho? could it have just been the new wheel drum shoes braking in? why is there still a 30mph 'wop wop wop'?
Insert Italian joke here... :LOL:
Okay, here goes.
Do you know why Italians don’t like to ride in a helicopter?
The front goes wop wop wop and the back goes ginnee ginnee ginnee…
Hey, I’m Polish, I earned the right
All in fun, the cute little brunette is as Italian as the day is long, and I love it!
Okay, here goes.
Drove my ranger to la jolla today to have a day of hearing and seeing the ocean. Went to mt Soledad also in la jolla.
Drove it to work... just like I drove it to school 25 years ago
Nobody on the radio was talking about the Pentagon collapsing this time. :icon_thumby:
Wow, really? That’s all that was on the TV for 48 hours over here in Atlanta, and it’s still going on, but maybe I pay more attention because I watched them build those towers from my bedroom window when I was a kid. I had folks from high school, college, and my kids neighborhoods, a couple dozen, that died that day. And we knew a couple first responders who died. One or two moderately close folks, but many that we knew.
Say a prayer, thank the Lord, bless our troops and first responders, never give up the faith, and God bless the United States of America, may she be preserved from those who want to undermine her.
Maybe the pump is not online with the others now? Can you out a straight edge across it and see if it align correctly to the others? It may be off alignment enough the edge is squeeking
In high school as i was driving to the local community college for CAD class the pentegon was actually collapsing after it got hit.
Upcoming TRS Events
Featured Ranger Based Vehicle
