sgtsandman
Automotive Technician
TRS 25th Anniversary
Ham Radio Operator
- Mar 11, 2017
- Aliquippa
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3L EcoBoost
- Automatic
- Tire Size
- 265/70R17
- My credo
- Anything that can go wrong, will go wrong. Plan for it as best you can.
Look at the cheapest/easiest things first then move to the more expensive/harder to do stuff if cheap/easy doesn't work. It is possible you have a slipped belt in a tire or some other defect.Rick W, I suppose I am more or less asking what is the likelyhood that I have a faulty bearing, axleshaft or brake shoes causing the noise?
Ill def check and see if those specific wheel wobbles has shifted tires since the tire rotations.
Also I buy my tires used from discount shops :|
It is possible one of the parts you installed are bad as well.
As an example, I had a bent rim that I wasn't aware was bent until I rotated my tires and it got installed on the front axle. It felt perfectly normal while it was on the back.
