I replaced a bearing, seal, axleshaft and drum brake shoes + springs on the rear passenger-side of my ranger. I found an axle shaft at pick-n-pull with very little wear on the bearing journal and used it.
Now when I drive, I am getting a loud tire thumping noise
I cannot hear it during acceleration. I hear it during mild throttle and while cruising and I definitely hear/feel it on the highway. it feel/sounds like a whopped tire.
I felt my rear tires for round-ness and they feel fine.
I jacked the rear end of my truck up and spun the tires and driver side rear wheel moves up and down ever so slightly and the pass side rear wheel moves side to side ever so slightly maybe 1/8in or less.
I also swapped my spare out between both rear wheels and i can still hear the 'thump thump thump' noise. i suppose I should swap the wheel out for the fronts as well.
I just got a job 1000 miles away and it would be nice to take the ranger and make a vacation out of one of these trips, though until I get this resolved, ill probably be sticking with the prius :x
Also I am looking at changing fluids on my 2nd gen prius and it seems like a daunting task, as If I perform any procedures wrong, i risk activating some sort of limp modes that may require my vehicle being sent to a shop to clear...
transmission fluid replacement seems simple enough.
pulling old brake fluid out and pushing new brake fluid in seems easy enough as well.
looks like I may want to pony up the $150-200 for motor and inverter coolant replacement.
advice?
