As per the title. I did the conversion, charged up my battery to full. At rest it has 13v, under load while cranking it'll go as low as 11.5v. I do have spark (weak) and at both the coil and the module, I have roughly the same voltage while cranking (11.5v).
Thanks.
Thanks.
Weak spark at that voltage implies bad coil to me, but I's sure a bad ground could cause it too. Is there any way you can test voltage directly across the coil terminals? Or resistance check the ground pin of coil to battery terminal.
