B2 Radio....wtf?
rusty ol ranger
2.9 Mafia-Don
⭐Supporting Member
Michigan
2.9L
86 B2.
The factory radio (clockless, electronically tuned, no cassette) no longer works after i had to pull the dash.
I had some issues with it before, so i bought another radio (factory style, just with clock and cassette)....its doing same shit the other ones doing.
Both will light up, power up, display is green, static comes through the speakers, everything works, but there is no display (numbers are gone)...it will not switch bands, nor will the stations change. Volume and equalizer works.
Do i have two bad radios or something in the wiring i messed up doing the dash? From what i can tell the display and tune dont have different power from everything else.
Any idea?
Either they are both bad or there’s a wiring fault somewhere. Factory radios weren’t the best.
Just sing like nobody is watching my friend.
I guess ill pull the one from the ranger then and try that....it works
If it’s powering on, I’m inclined to suspect an internal fault rather than a ground. But it’s weird that it’s happening on two units.
Two radios doing the same thing after you had the dash out... I would say wiring.
Also make sure you have the antenna hooked up.
It worked until you did the dash work?
I’m leaning that way too, but I’ve also pulled a radio that worked previously from a truck and dropped it in another truck only to have it not work anymore. More than once, and wiring was not the problem.
Try not to drop them and they hold up a lot better. :icon_thumby:
You know, I was waiting for that comment…
At least you didn’t disappoint this time.
You know radios and engines work better when you don’t submerge them too right?
B2 Radio....wtf?
Antenna is hooked up. That was first thing i thought of. Its also fitting in the hole good.
Yes. Well...mostly. Sometimes the the speakers would cut out until i would adjust the volume knob. I messed that up when i accidently broke a soder point trying to get it apart to change the display bulb. IIRC this is how it acted then.
I suspect the 2nd radio isnt any good. Damn marketplace...took my 40 bucks. I noticed when i had it plugged in the back speakers wernt working...but work fine with the original radio.
