'95 Supercab Rehab - Dumb Questions Thread
You guys are probably right that long arms are worth my time, but if I let it scope creep too much right now, the truck will still be up on jackstands instead of dewinterizing my boat.
I feel like for seating the coils easier, you really need pivot drop too, no? I can push the beams lower than the coils are tall, but the problem is the angle of the perch points the coil outward, away from the bucket. Single cab coils you just kind of fold in half, but the supercab coils don't bend like that.
You don’t need axle pivot drops until you get over about 2” or so, it becomes a ball joint adjustment issue where your ball joint adjustment is maxed out at 2-3”. What rolls the front axle is the stubby radius arms, being short they describe a sharp arc and the bushings don’t allow much movement. My Choptop, since I put long arms on it, I’ve never had a lot of trouble getting coils in or out, it does take a little fiddling and shoving to get the coils seated correctly, but the longer arms make a smoother arc that makes it easier to get everything where it needs to go.
I do understand that scope creep can be a real problem though, I’ve had it happen on projects and I’ve also had where I was trying to keep from expanding the scope and found something that needed fixed and forced scope creep. Guess it’s a vicious cycle if you work on your own stuff.
Interesting. Next on the list are bedliner swap, alignment, and body-lifting the cab, and long arms could go in with the latter since they're both welding projects. It's more the frame brackets I'd need to get everything planned out to minimize downtime.
Also not super stoked about punching the rivets to get the stock brackets off, since one of my hands has been jacked up.
With the spacer packs cut down, I've only got maybe 5/8" lift in front now, tops. Weird that the rear ended up so much higher on the old truck. It has junkyard leaves from IIRC an '03 B-Series, and both trucks have 3+1 leaf packs.
EDIT: New springs are definitely "B". Can't remember what the junkyard packs were. Is there a "K"? Are those taller?
When I did my extended arms for the 88, I bought joints, tube adapters and a prefab mount for the joint. I had to add to the prefab mount and do something about my transmission crossmember but overall it was less work than trying to build my own mounts from scratch like I did on my Choptop. I used Ballistic Fab parts for both builds and 2”x2”x0.250” square tube.
For rivets I like torching the heads off and punch them out hot. If I can’t do that I cut the head off and punch it out. Rivets aren’t much fun though.
Hey 😝, Before I jump all of you and say “no excuses,“ or “drop your crutches,“ you need to provide more personal details in your profile. I don’t like to beat up on the infirm and the aged (like me). 😘 🥹😂
I built most of the Road Ranger laying on my back or sitting in a chair when my leg was all messed up, and the last couple years I’ve been working with my left hand when my right hand went numb, then went through surgery, and after a year of Pt, has recovered to about 80%. With all I’ve been through for 71 years, I’m not going to let some hunk of iron kick my ass! Ford’s are worthy adversary!
Hah. Not fishing for sympathy, just pointing out it's a balance like everything else. I'm a seasonal volume bartender. If I break it worse, I can't make money with one hand.
No more space for big tools like a torch in my 1-car garage, but I should probably find a real air hammer. I tried a "medium" one at one point, and I might as well have been tapping shit with a jeweller's hammer.
I suspect I've messed up here, and I need to go extract what are actually 2.5" lift blocks from the old truck.
When I removed rivets (more to do) I found it fastest grind most of the way thru the head then use a very sharp chisel in my cheap air hammer. Would have to sharpen the chisel every rivet but it worked pretty good. Still time consuming.
This is what I do, cut a cross in the rivet head and chisel it off. Then a punch and 2lb hammer.
Aligned, bedliner-swapped, 1/2" back in the rear, and all is right with the world (except the carpet trim is still out).
Can anyone confirm 2.7ohm for the seatbelt sensor? Need to bypass so I don't have to worry about using whatever receiver I end up with.
Anyone want to swap black bumpers for my chrome? Not sure why shining the fucking sun in your eyes 24/7 was supposed to be a feature, but it might be the biggest downgrade from the old truck, and I never see any painted ones come up on car-part.
Fascinatingly, it seems like the seatbelt circuit might be fine with being open. Shorted reads no seatbelt, and the lowest resistor I have (47ohm) reads no seatbelt. Open turns the light off KOEO. Exact opposite of how it worked in my VW.
I'm not even sure the first year of airbags is smart enough for the bag to behave differently depending on the seatbelt sensor, which is what I really care about. I'm generally gonna be wearing it even if I've removed the sensor, and I want the airbag to behave normally.
Played myself again.
Since doing the cam sync, I've gotten intermittent 3x IIRC P0340 (Camshaft Position Sensor, nonspecific). That code doesn't make a ton of sense to me as intermittent, no other symptons, with new parts, unless it's a wiring problem.
So I bought a pigtail off Rockauto; figured I'd replace it if the code kept coming back. After the 3rd time, I tore it down, and realized they mislisted pigtails for the '96+ sensor. Worse, they don't seem to sell '95-down, nor does anybody else.
At least part of the problem's pretty obvious with the loom off:
Looks like duct tape in person.
Anyone have a lead on these things?
I'm honestly not sure what the deal was in there. There didn't end up being an obvious break in the signal wire; the tape was holding the drain wire folded over onto the shield. Based on the way the loom was sectioned and newer-and-older electrical tape--especially the green--I assume somebody was in there at some point, but it wasn't as hack as it looked.
I verified continuities and pulled some more wire out of the loom in case I have to go back in, but mostly I just tightened the pins and cleaned the drain ground G102 really well.
I also investigated and realized the truck doesn't actually seem to care how the sensor is oriented after you drop it in correctly, so maybe I have it "wrong", but it only rarely complains. There's a procedure with a breakout harness that I didn't do, since the drop-in alignment procedure put the sensor basically where it was before, which is notably clockwise.
In the limited pictures I can find of '95-down, it seems like most people's sensors point closer to straight back, or even slightly counter-clockwise from that.
Truck did great on its first major trip!
300mi loop to pick up some equipment. No CEL, no bullshit, ~14.5mpg with A/C, towing, and shit on the ladder rack, which is pretty much the same as the Lima would get, but 10000x more comfortably.
Since yesterday, getting repetitive RPM surge on decel out-of-gear. Drives fine. Doesn't act up under any other conditions, including stationary idle.
Gonna throw an IAC at it and go over the vac lines, but I just replaced pretty much all of them a few months ago. I have the main vac source off the intake reduced and teed; is that too restrictive vs. the original setup? Not really sure how to reproduce the three tiny, brittle red lines coming out of one large fitting.
I’m having the same problem on my 87 2.9. It absolutely runs like a top, but the idol seems to go wherever it wants when I take my foot off the gas and put the clutch in. It doesn’t over rev, but it wanders around a little bit higher than it should.
Any checklist on what to check would be greatly appreciated
You have A/C? I know mine has a slow leak, and I'm also wondering if maybe fast idle for A/C demand compensation is engaging and disengaging for some reason. Might explain why it's happening now that it's really hot.
