06 Frame Repairs
I need some advice for the rockers, anyone ever do those aluminum slip on covers with the sheet metal screws for $70?
Never did aluminum ones. I’ve installed a few steel rocker slip covers for a couple people on various vehicles. I usually weld them in other than rivets in the holes that I used for Cleco pins when I’m fitting them up. Sometimes I’ve had to make adjustments, sometimes not.
I've done the rivet on style steel ones. They don't sell anything other than those aluminum slip ons for rangers. All I see online is people replacing the whole rocker, which is correct, but I'm on a budget/time constraint lol.
Totally get the budget/time constraints. I haven’t gone looking for rocker bits for my Ranger for awhile. My one 00 needs a rocker repaired but I’ll probably just cut out the damage and form a piece of sheet steel to fit because my current budget isn’t really allowing another option and it’s a relatively small spot, plus I have sheet steel on hand.
Yeah, my whole rocker on both sides is piece mailed with grit tape, bondo and spray paint. It looks whole. But that's it.
I plan to get it inspected as is, it will pass, but next year it won't.
This is Sokka
06 Frame Repairs
Now, back to the episode, we got the shackles and mounts on, one of the eBay shackle mount bolts snapped at 55ft/lbs, so I had a grade 5 to replace it. Everything torqued to roughly 70ft/lbs.
The original shackles would not move under the full weight of my fat ass on a 3' breaker bar. (900ft/lbs?)
The daughter was a huge help.
06 Frame Repairs
06 Frame Repairs
06 Frame Repairs
