>> OK, but WHICH Vgate Vlinker version to get?
fixizin
FoMoCo is forcing me to buy a 'yota
⭐Supporting Member
Fort Lauderdale
FL - USA
Other
FLEX-fuel, baby!
Drive
3.0L
0" bone stock
P235/75R15
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
WiFi? Bluetooth? USB-cable? MC+ super-pro?
Thanks in advance... #LostInToyland
I got the ones recommended by Forscan. The direct wire connect seems to be a little bit quicker, but you do have the inconvenience of the cable being in the way and having to move the switch back and forth as prompted by Forscan.
The bluetooth unit works fine, just a little slower. I've not had a problem with either adapter though.
I bought the recommended USB version because if you’re messing around with PATS or anything else important they highly recommend a wired connection because a dropped connection in the middle of the process could brick the ECU
Like with all things... buy once cry once.
At that time... those two units were the only interfaces that were recommended by ForScan... right from their website.
I wasn't going to argue... Just paid the price. Which has went up 20-25% since I bought them.
When i bought mine like 6 years ago almost to the day... these were recommended by ForScan.
Is this the one? Sometimes Amazon plays tricks on me with links from the states and tries to foist some more expensive crap on me.
The non Bluetooth ones are $30-35 for the good ones.
Just need to be able to connect your laptop to it with the usb cable.
Also, Forescan recommends only using the cable version for making changes. If the wireless connection gets broken during a parameter change you can brick the model.
Wireless models are only recommended for diagnostic purposes. They are good because the laptop can be outside the cabin next to where you are working.
I also went with the recommended vgate vLinker from forscan. Worked first time no problem.
