Reusing Refrigerant After the Black Death?
Cincinnati
OH - USA
Other
1990 Mazda Miata
Vehicle
Drive
Howdy folks,
AC blowing hot as summer begins rearing its ugly head. I had a local mechanic vacuum out the refrigerant (r134a) so I could investigate, and I discovered the black death had struck. I will be replacing everything I need to but I have one concern: The mechanic said it will be fine to put the old refrigerant back into the system once I get everything replaced, but I don't want all my work to be for nothing by putting contaminated refrigerant into the new clean system. Would a proper AC vacuum pump system at a mechanic be able to filter out the contaminants caused by the black death, or should I just put fresh refrigerant in?
most ac recovery systems have filtration on them already
What's the black death?
Catastrophic AC compressor failure which contaminates the whole AC system. Requires a complete replacement of every AC component except the evaporator. It's a well documented Ford issue.
Not really a Ford issue, it is a A/C compressor issue.
Either they make cold air or blackness and dispair.
A modern reclaiming machine will filter out whatever impurities there are in the freon.
It's not a "Ford issue", it's universal to anything with a compressor. Most of the components can be flushed with solvent- at least all the lines can if you're concerned about trapped particles.
Ditto the question is if it was filtered. Definitionally "recycling" mean filtering. "Recovery" doesn't, necessarily.
I wouldn't reuse refrigerant because it's not expensive and I don't have a recycler. I would assume an actual A/C shop does, and if they're gonna warranty the job, they can do whatever.
The charging station we used filtered the recovered freon and we reused it with no problems.
