Shakey idle and sluggish take off
ryan445
Fort Worth
TX - USA
Other
Mach E
Vehicle
Drive
2.9L
Hello.
4 years ago I parked my 87 Ranger. One day while driving to work it start feeling strange driving down the highway. When I got off the high way it stumbled at a stop and almost stalled taking off.
4 years later I replaced the 02 sensor and that seemed to fix that issue. I noticed that while idling, it's shaking a little and you can hear a slight miss in the tone of the engine.
Replaced spark plugs. Notice some were a little fouled from a rich mixture. No difference made. I then replace the air temp sensor on the intake plenum and cleaned the throttle body at the same time. It was pretty fouled up and that seemed to help some but still rough and laggy.
The engine smooths out when you give it gas but it's just lagging more then normal for the 2.9l. no codes on KOER but I get TPS code on KOEO.
Not certain that is the cause of my woes though. Its it not smoking out the exhaust, doesn't smell rich, no coolant in oil or vise versa.
Next on my list is to replace the injectors l, but don't wanna keep throwing parts at it that may not fix it.
Also checked for vacuum leaks, fuel in the regulator vacuum line, cap, rotor and wires don't have many miles on them.
Also to note: old gas was drained from the tank and fresh gas was put in after the sit. Its been through 4 tanks with some seafoam.
Edit: Also to add sometimes, not all the time, if I gun it. It will suddenly loose power at the top end of the power band. You can feel the truck stall and see the rpm drop and pick back up.
If its throwing a TPS code that would be the first thing id inspect.
Check it for 5v reference voltage, if thats there id replace it.
It’s also pretty easy to check that you get a smooth change in resistance as the butterfly goes from closed to open and vice versa. You’ll just need to determine which 2 of the three pins are that circuit. Spikes or drops in the resistance will mean the computer is getting a bad voltage signal at those points.
You also need an analog meter to properly check the sweep of the tps
At rest I am reading .72 volts. Slowly sweeping the throttle to WOT it does increase smoothly and tops out at 4.15v
Find a ECM pinout and a buddy and make sure the signal is getting to the computer
What is the voltage reading for the 5v reference wire? At WOT the signal wire should be the same, and 4,15v is on the low side for the signal. Once you track down the pins on the ECM plug I would check the three lines for resistance, which shouldn't be there.
Definitely get your TPS code sorted out first, but before replacing the injectors I would try cleaning them out. The cylinders that are not running rich may be doing so because the injectors aren't flowing as they should (and the ECM is running the injectors longer). Sitting four years can cause that sort of problem.
I got 5 volts coming from the computer. And voltage is making back from the TPS.
I re-ran the KOEO test and got the pass code. Messed with the throttle body and wires a bit to see if it would come back and it has stayed away this far.
Still idles crappy. On high idle from cold start is when you hear the miss in the sound of engine.
However, while poking around I may have found my culprit or at least a small contributor. I have a Duralast of ignition coil I threw on it who knows how long ago. When the engine warms up you can hear it clicking with the rhythm of the distributor and I suspect an internal short. All this time tinkering around it though it was the injectors I was hearing. If I remember correctly I threw a duralast TFI in it as well at the same time.
On a note: you mentioned to clean them. I am guessing you mean to take them out and manually clean them. Sorry if that's a dumb question. I've always just thrown a can of cleaner in the gas tank every so often.
EDIT: shortly after posting this I decided to pull the cap to look for carbon tracks even though I know it's not that old and one of the wires to the spark plug separated...... Easily may I add. So also may have compounded this issue.
Well guys...... Looks like I've been lying to myself for the past few weeks.
Cap and rotor are have carbon on them. Let me replace cap, rotor and wires and go from there..... Should have done it with the fouled plugs instead of taking short cuts.
  • Shakey idle and sluggish take off
Unless I'm missing something in those photos, that cap and rotor doesn't look much worse than what I usually pull off mine when I finally get around to changing it, and electrical misses haven't been a problem for me. The bad plug wire sounds like it could have been an issue. Still, one bad plug wire would not explain 3 fouled plugs.
If you've been running fuel system cleaner regularly you may not have dirty injectors, but if you're a DIY'er this is worth knowing about. If everything electrical checks out okay but you still have cylinders running rich and lean, this may be worth doing. You'll find YouTube videos showing different versions of this process. You hold the injector open using a 9v battery and test leads. 12v will damage the injectors. Then using something like a syringe you force cleaner through them. First you can test if they don't close completely by leaving the battery off. Catch what sprays out the pintel end so you can see if it's dirty and see when the cleaner flows through clear. I've used throttle body cleaner because it's better around electrical components than carb cleaner, but you'll see videos with people using carb cleaner. A couple of years ago you could get a kit with new screens, pintel caps and o-rings for about $25. The Injector Shop has an EBay store.
Its worth a try if all else fails.
These injectors are most likely original and I'm sure 4 year old gas was still in the lines and could have gummed them up. I've only ran seafoam through the tank with the fresh gas, but could probably do something stronger if I want to try that before pulling injectors.
I got a cap/rotor/wire set on order along with a motorcraft coil. I definitely don't like the ticking sound coming from that duralast coil regardless if it's an issue or not.
Thanks for the information. I will keep you guys appraised as this progresses. I want to keep this old 2.9 alive even though most people hate it lol.
Alright guys. I got the coil in today and I just gotta say. The replacement motorcraft one vs the AutoZone one is night and day compared. Quality and weight. The motorcraft is slightly heavier than the duralast.
I got cap, rotor plugs and a fuel filter coming in tomorrow. Should be a good little weekend project. Also got some of this stuff : https://a.co/d/0cJHeQsV
The research I did showed this to have some of the highest concentration of PEA so I hope if any of my injectors are in need of help, this helps them some how.
If not then I will attempt to clean/rebuild these old injectors. Reading around these forums many people have had rotten luck with aftermarket injectors so I wanna avoid that.
If I get time this weekend to throw everything back together, I'll let y'all know how it's running.
I put cheap ebay injectors in my ranger and had no issues.
Good to know. I saw some sellers had a complete set of Bosch ones for 80 bucks or less.
You really gotta watch on there for counterfits
Upcoming TRS Events
Featured Ranger Based Vehicle
