Shakey idle and sluggish take off
ryan445
Fort Worth
TX - USA
Other
Mach E
Vehicle
Drive
Hello.
4 years ago I parked my 87 Ranger. One day while driving to work it start feeling strange driving down the highway. When I got off the high way it stumbled at a stop and almost stalled taking off.
4 years later I replaced the 02 sensor and that seemed to fix that issue. I noticed that while idling, it's shaking a little and you can hear a slight miss in the tone of the engine.
Replaced spark plugs. Notice some were a little fouled from a rich mixture. No difference made. I then replace the air temp sensor on the intake plenum and cleaned the throttle body at the same time. It was pretty fouled up and that seemed to help some but still rough and laggy.
The engine smooths out when you give it gas but it's just lagging more then normal for the 2.9l. no codes on KOER but I get TPS code on KOEO.
Not certain that is the cause of my woes though. Its it not smoking out the exhaust, doesn't smell rich, no coolant in oil or vise versa.
Next on my list is to replace the injectors l, but don't wanna keep throwing parts at it that may not fix it.
Also checked for vacuum leaks, fuel in the regulator vacuum line, cap, rotor and wires don't have many miles on them.
Also to note: old gas was drained from the tank and fresh gas was put in after the sit. Its been through 4 tanks with some seafoam.
Edit: Also to add sometimes, not all the time, if I gun it. It will suddenly loose power at the top end of the power band. You can feel the truck stall and see the rpm drop and pick back up.
If its throwing a TPS code that would be the first thing id inspect.
Check it for 5v reference voltage, if thats there id replace it.
It’s also pretty easy to check that you get a smooth change in resistance as the butterfly goes from closed to open and vice versa. You’ll just need to determine which 2 of the three pins are that circuit. Spikes or drops in the resistance will mean the computer is getting a bad voltage signal at those points.
You also need an analog meter to properly check the sweep of the tps
At rest I am reading .72 volts. Slowly sweeping the throttle to WOT it does increase smoothly and tops out at 4.15v
Find a ECM pinout and a buddy and make sure the signal is getting to the computer
