Front Fuel Leak 1993 Ranger 4.0 XLT Auto
Google Ai sent me this info back when I inquired about that fitting, is Google correct?
I figured it was threaded. I was wondering how I would get a disconnect tool on that fitting. 🫪
So that's a stock fitting and stock fuel line?
Yup, totally stock.
Ford used braided lines from the rail to the quick connects then went to nylon for a lot of years
@Curious Hound @lil_
Yup, totally stock.
@Curious Hound
@lil_Blue_Ford
I guess this is my final step,,,, acquiring the correct fuel line and or fittings etc to make up. I'm wondering now if that Dorman kit fuel line set (800-063) I purchased will work, its coming today (the last photo below). It doesn't look close to the fitting on the Ranger, more like this first image below.
Evil Energy
makes this thread fitting which looks like it will work, but the question is will this fitting shown in the photo below interface/connect with the PTFE line, in which I would have to make up myself? I believe they have 5/16 also.
This is the original fuel line with elbow fitting on the fuel pressure regulator.
The Dorman Kit 800-063 I purchased. This kit is questionable.
I'm pretty sure that Dorman kit is fittings that should fit the fuel pump and or filter. Not at the engine.
AFAIK nobody makes the fitting at the engine. The ones on the other side of the braided line are available IIRC.
I need to pull out one of my old fuel rails and see if I can get a machinist to make up a few fittings…
Im thinking that I may keep the existing fittings intact and just clip the old line about 2 inches or so away from the stock fitting and run new ptfe lines. Your thoughts?
